i own a k1 cupra and i have to admit the handling on the car is good but wen i throw the car in to corners the back always drifts out alot its easy to control but i just wanted to find out if any1 elses cupra does this?
esp's on sometimes had it off once yeh i think ur ryt i throw it in alot because im used to the r32 4 wheel drive system i used to own 1 before on the way home from work ill try it smoothly round corners see how it goes
the FR's have a fairly loose rear end as well. Mine felt a bit loose when taking fast corners, without chucking the car into the corner. The rear end would a bit twitchy. you'll really have to change part of the suspension set-up to correct this. I've got mine lowered on coilover and thicker ARBs (front and rear) and it now corners high speed corners without a twitch.
Probably the best starting point is thicker ARBs. not that expensive too.
