hi i am looking for any options to improve my handling on my seat leon cupra tdi
. the car has done 120000 so its starting to feel abit slugish . will replacing the ball joints , rod ends, drop links , roll bar links etc change anything really
. was looking for a aftermarket that could sell uprated parts instead of just replacing them with the standard jobbies or are they just as good . the car has 18"s on so that improved it abit but not enought . i would consider dropping it but the council around here have decided the build brick walls 4 speed bumps
, i could maybe go 25mm to 30mm lower if any one could suggest a decent spring that they are running on . also do you actually gain anything out of solid engine mounts or does it just make the drive of the car worse . any suggestions links or pics would be a great help . cheers
