Right a lil update!!!
Got my Spax 60mm lowering springs last week, since it was sunny this afternoon went to fit them after fixing the passat cos it blew a boost pipe off hehe.
Took the Koni shocks off the car, removed the Koni spring and placed the Spax ones in place..... built the suspension back up, placed the bump stop on then the spring top plate, went to put the bearing on and the bearing sat about 25mm higher than the plate so it's no where near the plate to compress the spring!
If I built it all up the spring would just move around and is not compressed in anyway.... basically the Koni shock is too long for the 60mm springs
I know when the weight of the car is on the springs it will compress but if I was ever to get 4 wheel lift off
The spring would just move where ever it liked, to be that is not good and def not safe!
Soooooo rung Koni see about the coilover kit, said
Ibiza 96-99 except Cupra Sport and Diesel
Thinking Bilstein coilovers now.
