Now, I had an Ibiza 1.9TDI I fitted my HID's to that car and was never quite happy with the height of the beam. Now I have a cupra and the same applys so I'm obviously doing something wrong.
Now, Most people say "My HID's are too bright, Or too high up, or people are flashing me"
Mine is the other way round, The brightest part of the light which should be around steering wheel height is nearly pointing at the ground.
Some of the light is escaping to say... steering wheel height but its not supposed to be like that, So I've got some questions.
http://picasaweb.google.com/lh/photo/Hj5Yppzra0L0FpYW87AgFA?feat=directlink
That arrow points to exactly where the light is projected... is that correct? It seems the light is projected straight upwards and bounces straight off the top part of the reflector lense....
The underside and tip of the bulb are coated in something that I assume is meant to reduce glare however these headlights now have a "grill" type thing over where the tip of the bulb is so I'm sure I dont really need this "Anti Glare bulb now"
Basically the Should the light be projected directly upwards?
I've set my headlights via the switch in the car so their as "High" as they'll go and I've lifted the bonnet and adjust this dial
http://picasaweb.google.com/lh/photo/FUP3ty8EAkPQ-NvYOVlQcA?feat=directlink
as high as they'll go, its gone pretty tight to turn. Obviously I dont want to try to hard as I might break something.
Is there any other way of adjusting?
I know the response will be "TAKE IT TO A GARAGE!" but all I'm armed with for the next few days are some screwdrivers and allen keys until I can get to one.
Any suggestions?
Any suggestions?
had then all aligned today and the
