they are for mk4 ibiza and liams polo...
drivers side one is all new, the other side is made out of the standard mount
cam belt side is £150
gbox side special is £200
+vat
to hold 400 horses you have to use proper mounts else it will tear itself out of the engine and reek all sorts of havoc
some re-install pictures... it is going back together honest.
scuttle going back in thanks to some creativity from tony.
turbo heat tea cosy off mine on there, and something like this one will be added properly.
the scuttle is being boxed in, and heatshielded around to protect the bulkhead & wiring running past it
manifold is on to stay, VT mounts all on, fettling this scuttle and heatshielding, then DP on finally, exhaust... and thats done.
got all weekend on it so should see some good progress.
okies.. sundays update for ya.
tired and going home now..
mocked up in place to check the boxed bulkhead section behind the turbo is correct with DP in position etc etc.. heatshielding will be attached to the inside face of this tomorrow when i weld it fully, paint etc etc
