Probably the belt getting wet and slipping. Mk2 golf had a spash guard for this.
I have exactly the same problem. Only in extra wet weather. It only started after I took off the underside engine cover off due to an oil leak. Most people said its fine with this off... I wonder how many this affects who have left it off?? It is scary as hell, so now drive like an oap with 2 hands CLAMPED on the wheel @ 14:50 position whenever its raining!
For those not too up on mechanics, in tightening it up, would that be the thin belt on the drivers side just in front of the wheel? Got 3 bolts to slacken?! If so, Sundays job...
as m0rk's said, just tighten the PAS belt, job done....
What would the tool be thats needed to loosen these bolts? What size? I dont want to botch them up with my vast collection of mole grips! Got my 3 year old son to keep the wheels on full lock and bobs your uncle, one slipping and squeeking pas belt!
i did it today, they were all 13mm (if under the car looking up, so legs facing the front of car)
there is 2 bolts on the right side of PAS Pump (one noticeable, other just up from it)
and 1 bolt on the left of PAS Pump
loosen them, then get something to lever the pump so it goes towards the front of car, and then tighten up nuts, took me 5mins exactly (but i did have a ramp, so much easier)
