fluffmitten
1. Probably the radiator fan, these are electrically controlled but you do not need the ignition on for it to work. Quite common for them to keep running for a minute or two after switching off.
2. Don`t PUSH your bonnet closed, drop it from about a couple of feet above the shut.
It will lockif you are unsure just drop it again!
Brilliant, I'll be so relieved if it's just the fan, cheers!
Top tip about the bonnet thanks, it does work better but I'm just worried about dropping it too hard and damaging it - I was surprised how bendable it felt when I tried pushing it carefully
