kbird
Is the roof spoiler on an LCR different than on a 20VT/FR/Cupra? Also did SEAT offer a body kit for a LCR with a bigger roof spoiler? Thanks
As far as I am aware the spolier is the same size throughout the Leon range but body coloured on the top end models (FR/Cupra/LCR etc).
There was no body kit option for the LCR but you could get a limited edition FR with the LCR body kit and 17" wheels excluding the Bremobos.
I think you would need to go aftermarket if you are looking for something larger...
Hope this helps! :D
Hi DPJ, how does your lower spoiler affect the handling of the car?
It's always been on the car, so I can't say what effect it has. The car is very stable at high speed. Since I went big turbo, a number of stress marks have appeared in the paint on the spoiler, I think from downforce. :shrug:
* sorry, you also mentioned discs a little while ago. I don't get any noise in reverse with mine,
Hi Dave, I have alway been impressed with how solid the LCR feels even in standard guise.
Do you get lift on the front? I imagine your acceleration is pretty ferocious and such a large rear spoiler would put quite a lot of force on the rear!!?!!!?? My brakes are just plain embarassing in day to day life but on the track they really prooved their worth, I was braking far later than most of the other cars and had no signs of fading after 10 pretty hard laps. :D
I have AP racing disks on front with standard VAG on the back and Mintex 1155/44s on the front and rear - what set-up are you running?
LCR Roof/Tailgate Spoiler Options
I race a an LCR and need a better roof spoiler, does anyone know what genuine dealer fit options were availbe as these are the only parts I am able to fit? Thanks
Is this the car run in the castle combe saloons?
What about mocking up something like the old Super Copa's ran? Cut through the rear screen (perspex) and secured to the inside of the door
http://www.seatcupra.net/gallery/ma...ownloadItem&g2_itemId=10422&g2_serialNumber=3
Should be pretty easy to fab something up like that (assuming you can get hold of that wing)
i know it would look ugly but couldnt it be bolted to the tail gate itself ?
if your a good track driver most people will only see the rear of your car :D
The one above is bolted in two or more places down long mounting rods.
This will save bending and flexing but still allow this to be light weight.
Thanks for the comments. Yes it is the car in the Castle Combe Saloons. I have been using a 'Gurney Flap' on the roof spoiler but it is not permitted for next year but I can fit any genuine SEAT part. I have a 'Cup' wing and bracket which can be mounted on the outside as suggested but I am waiting for confirmation that it is available from any SEAT dealer. I thought maybe there was a BTCC type body kit available?
I thought you might be interested in the cars spec;
Engine/Transmission - Billet Steel Crankshaft, JE pistons, ARP Bolts, Head Bolt Conversion, Scat Rods, Supertech valves/springs, CNC flowed head with Cat Cams and solid lifters, line bored and balanced, Neuspeed pullies, Garrett ball bearing type Turbo with external waste gate by Owen Developments, Hypertune inlet manifold with Spec R intercooler, adjustable cam pulleys, Bailey dump valve, engine oil cooler plus power steering fluid cooler, Acusump, free flow large bore exhaust system (93Db), Big injectors, comp fuel pump & swirl pot, Samco hoses etc, 6 speed box Cupra Cup gear box with LSD, quick shift, rose jointed gear linkage,
Suspension & Brakes - Custom made Ohlins coil overs - 2.25" dia springs, Fully adjustable top mounts, AP 6-pots with bell mounted discs, Pagid RS15's, Tilton bulkhead mounted top hinged pedal box, Racetech quick release OMP steering wheel
Bodyshell - Right Hand Drive, Full multi point weld-in cage, Recaro Proracer HANS SP-G XL seat, Willans 3" Silverstone 6x6 harness with alloy adjusters, electric fire ex system, mountings for passenger seat, carbon fibre door cards, waterproof breathable custom cover, Widened steel front wings, Heated Front Windscreen
Electrics - Full custom harness by GWR Motorsport with detachable engine harness for dyno installations, Motec M400, AIM MXL Pista Display with full data logging, GPS and Memory Stick, Owen Developments switchable rain map. Fuel sampling facility, road legal lighting
Wheels & Tyres - 6 No. 8.5 x 18 BBS CH Motorsport Alloys
Cool spec of the car... I guess it's the crimson one?
Anyway... Sadly the wing isn't a Dealer part (and a quick check on the SEAT accessory website shows that there are no 'styling' parts any more)
I'm very interested in this as I'm prepping my car for track days just now.
Could you do a build thread in the readers rides section. I'd be VERY interested in the finer points of this with pictures etc.
There would be many more guys interested in this too. We have a guy from Holland with a MK2 Leon Cupra track car with a build thread, this would give us MK1 boys something to aspire to.
If I can find time and photo's etc I will do
