should fit, 80mm maf is what you have so mite be worth asking if its that size.
good price that aswell. looks a decent filter with no oiling needed.
I don't know if this is true or not but I was told the quickshift filters offer good performance gains due to them not being restrictive BUT this also means they suck a lot of crap in?
I guess this is generally true as I'd imagin its pretty impossible to be unrestrictive to both air and debris.
Same sort of results here with this dry metal filter
http://www.mkiv.com/techarticles/filters_test/2/
i have one of these on my lcr and its graet.
the noise is like no other iv heard it has the k,n style rumble at low revs but then sounds like a jet when your going some,
it dosnt seem to collect too much crapon to it and it looks v.nice under the bonnet.:)
yeah thats what i want a good induction noise, have you got any videos?
doesnt look to bad tbf ... maybe worth trying it out for £64 how would you go about fitting it to an lc tho maybe make an adapter plate ???? could also maybe use filter oil to try and see if it traps any crap ???
I had an adaptor plate made dude for my 1.6;
Something similar to that
Fitted
Jimski
should be a stright fit on the lcr, just a mounting bracket to be fabricated
