I'll try to remember to mearure how much space I have tomorrow. Think I'll be lucky to have 50mm.
What g/s are you pulling?
last time i logged @ Revo-Cargate Greece arround 180+g/s
without the spacer most of us read 170...
Need to log my car myself, i just didnt have the time lately...since temps are a lot lower now...the evo heatshield works very well no the car reducing the CFs... ;)
im fitting this ITG filter to mine on saturday with 75mm spacer its going to be a very tight fit
Fitted this today, was a tight fit but it went on ok, Induction noise is very loud now sounds like a hoover in the glove box not sure if i can be doing with the noise tho it may do my head in after a while.
It is like that with all cone fillters...
forge 006- 007
forge tip
N249 bypass
Cone filter
removal of the bonnet rubber seal...
Is the recipe for HOURS and Hours of enjoyment....
forge 006- 007
forge tip
N249 bypass
Cone filter
+ remove sound deadening from under bonnet = mega smiles for months!
Thanks for all the feedback mates.. I went and got a nice filter, problem is that the filter size is 80mm and the MAF area is 70mm. I got a sillicon hose with 90degree bend, what can I use so the 76mm will go over the MAF and tighten nicely? It's right for the filter opening, just need a reducer I guess.
