The Stalk lead i've ordered comes with the CANBUS adapter so no other leads required on that front.
What i want to know is how you secured your unit because all i can is that it will fit into the facia and has nothing to clamp to on either side.
My head unit comes with a cage and brackets but the brackets will still not make it wide enough to attach.
This is getting so flippin frustrating
Do you have a picture of what doesnt fit where? The cage of the headunit should fit the hole in your facia, if its a DIN size fitment hole. If you have a seat navifacia, then its a problem and that can be solved atleast with the same VW 1-DIN adapter that I used. There are pictures on this forum somewhere.
EDIT: oops you have a 2-DIN unit. I dont know if there is an original part for this.
