what is it can someone explain?
WIKIPEDIA said:In internal combustion engines, water injection, also known as anti-detonant injection, is a method for cooling the combustion chambers of engines by adding water to the cylinder or incoming fuel-air mixture, allowing for greater compression ratios and largely eliminating the problem of engine knocking (detonation). This effectively increases the octane rating of the fuel, meaning that performance gains can be obtained when used in conjunction with a supercharger or turbocharger, altered spark ignition timing, and other modifications.
Anyone installed a water methanol kit to their cars? i'm thinking of buying the water methanol kit for my cupra tdi, they say gains of 70BHP but thats bullprob be around 20-25BHP max. any ideas, is it worth the upgrade even with FMIC?
cheers guys
Isn't the guy, devonutipzxy (guy with the crazy fast fabia) running methanol on his tdi?
thats devonutopia. He is running it in his furby and I think I'm right in saying he's pushing something like 260ps (130ps standard) but obviously he's got other mods too.
try PM'ing him or looking on briskoda
With the help of Wikipedia...
DPJ & Probee are both running Water Meth, albeit on Leon's, but any questions may be worth asking them as both know what they are going on about. Sure there are others running it these fellas are the 1st to spring to mind.![]()
You'll be lucky to see anything more than 20bhp on a DERV. Devonutopia is also running a hybrid turbo and nitrous. T.Spark saw a slight gain from fitting it, but nothing massive. More to reduce smoke levels.
Personally, at the stage you are at, I'd save the money and put it into a hybrid turbo fund![]()
Ah didnt realise you already had a hybrid mate. What sort of power you making at the moment then?
Few others running it on mk4's tooGot a kit sat in my garage at home waiting to go on, and i know Mikey-h with the yellow hybrid PD130 is also running it.
spitfire performance do kits, was tempted before but not sure if it would damage the engine!
how do u get refills?
wat sort of costs are we looking at for the kit?
is it? wicked! not for now tho, just got the hybrid done on the car, went to get remap, changed the oil before to get it running nice and the thread came out with the sump bolt!!!
not the best of days today!
you think the methenol would give much gains, is it worth getting?
another quick question, would you need to get the car mapped again with this added?
