Deleted member 39269
Right folks here's something to get you thinking! :p
Tonight when just about to go out i went to start the car and it took a couple of turns before it fired. When it started it had a lumpy idle for a few seconds which then cleared and it ran fine
Set of to my work and the car drove like normal. Switched the car of at my work and went to start it again and it wont fire
Pluged in and it came up with
-Camshaft sensor fault
-Bank 1 lambda sensor fault
-Coolant sensor fault
So i've change the camshaft sensor still no luck
Checked plugs and there were wet from fuel so thats all ok it seems.
Removed number 1 coil and put a plug in and lent it against the rocker cover and i got a spark
Any ideas folks? I dont no what to try next?
Thanks in advance
It had a camshaft error code when it was mapped so that was the first thing i tried
The belt seems tight no obvious signs of torn belt lying in the cover or anything
mine was coming up with camshaft sensor out of sequence and camshaft sensor out of performance when my cambelt slipped 7 teeth. still ran ok, just was hard to start. so its possible your cambelt has slipped. other thing disconect your maf
Thanks in advance
The coolant sensor on my 1.4 was gone and making the auto choke stay on, which caused it to over fuel and not start up first time (only after short journeys i noticed). No idea if it can cause similar issues with the cupra but got one of fleabay for £13 and with a bit of coolant changed it myself. (again presuming its similar)
Ricko
i don't think its my cambelt as it ran just as normal before i switched it off
Ricko
yeah i think this problem. Am going to try a new one today and see if i have any luck
I no whats wrong now. Coolant temp sensor. THe car fires up and runs straight away when cold but if its hot it won't so i'll get on ordered tomorow
Thanks for the help guys
mine was fine the day before, went to start it in the morning and it kept turning over and then finaly started up, missed a bit for a few seconds then ran fine, every so often it would bang very loud whilst turning over
bust lambda causes over fueling i know that much.
Well i think because the coolant sensor isn't working correctly it's over fueling because it thinks the engine is cold
So this would through up a lambda fault because it will be running on a cold setting when the engine is warm
Well it fired up straight away today because it was cold... But when it warmed up and you went to start it again it would just turn over
I think because the sensor isn't working it's using the automatic choke and put to much fuel into the cylinders and flooding them
Right got the car going yesterday with the new sensor fitted all good!
But then on the way home the car started running poorly! Plugged into it and no fault codes apart from the camshaft position sensor fault
The car idles fine but when u foot your foot down it splutters and hesitates like mad and if you hold your foot down sometimes it runs fine and pulls really well
So far i've changed plugs, disconnected the maf, checked coil wiring and earths, fuel filter changed and also replaced the 'O' rings on the FPR
I really don't what to do next?
I have change 2 for new ones already and swapped them about and still no luck? Tried holding a rev whilst unplugging them bit you cant tell the difference
