Deleted member 39269
Right folks here's something to get you thinking!
Tonight when just about to go out i went to start the car and it took a couple of turns before it fired. When it started it had a lumpy idle for a few seconds which then cleared and it ran fine
Set of to my work and the car drove like normal. Switched the car of at my work and went to start it again and it wont fire
Pluged in and it came up with
-Camshaft sensor fault
-Bank 1 lambda sensor fault
-Coolant sensor fault
So i've change the camshaft sensor still no luck
Checked plugs and there were wet from fuel so thats all ok it seems.
Removed number 1 coil and put a plug in and lent it against the rocker cover and i got a spark
Any ideas folks? I dont no what to try next?
Thanks in advance
Thanks in advance
