great_kahn
Spooge
Nov 19, 2009
2,415
Leicestershire
Hey guys, just about to order a forge strut brace, green panel filter, and a vag flip key for my cupra tdi. Ive done some reading on the subject but couldnt find a definite answer for this issue. The online instructions for the green panel filter say that it should be oiled after it is cleaned... however i have read some posts saying that this could ruin the MAF?
One or two posts from people who run the filter dry to avoid the issue. Any advice before i click buy, any other filters i should look at instead?
Tom
when you buy a cleaning kit it wil come with some spray oil iv just washed and oiled mine no problems so far.
Do the panels come already oiled? i noticed that the pipercross panels have exactly the same instructions pretty much. Im thinking the amount of oil you have to apply is tiny?
when i purchased one i looked into this and the green pigment is the colour of the oil. it should be a light coating of oil otherwise may lead to MAF problems as you have mentioned.
in the end i didn't see much point so sold it on as i won't be going past stage 1 remap
Ye i didnt get one in the end, ordered a nice shiny forge strut brace though. I just cant find enough info about the maf issue for me to decide. For 1 or 2 bhp gain i cant see the point in blowing a 100 quid maf.
So long as you don't spray loads of oil on it so it's dripping off it, should be fine. I cleaned and re-oiled mine without any issues.
If it is not oiled then it won`t be filtering properly, the oil Helps filtration as well as the filter cross-section. As long as you follow the instrucions you get with the cleaning kits, oil the correct side and don`t over-oil, it will be fine.
There is no noticable difference between the GREEN and the K+N panel filters (I have the K+N), so it depends on price really.
Cheers mate, im gonna get one, does mean i have to take the strut brace off to get it on though :lol: awwww bugger, shoulda thought about that a bit more.
its k and n that hav poroblems with maf not green filters
the difrence is k and n use a 5 layer gauze system and this can get rather large holesi n is easy and allow more dirt to get thru the filter this then gets on the hot wire and knackers the maf
the green filter is a 2 layer cotton system that is like a t shirt it much harder to get a hole in it than the k and n and also allows for beter airflow
