If it's a coin won't they charge you to fix it? Since it's not something wrong with the car from the factory?
Happened with my 2.0 Sport. Lost a 50p down there and it broke. They replaced it under warranty with an Access Plus seat. A tilt and slide mechanism as opposed to the basic tilt one that was originally there. :D
Is it simply that the seat will not slide on the rails? or is it a case of the handle on the side of the seat not tilting the backrest? if its the second one, i found the wire that pulled the release latch had fallen off inside the seat cushion, which meant it being ripped apart for me!
its may not be a coin the cable itself might need replaced, it th little handle in which u pull to release the seat very light or loose (the one up the top side of the seat)
