Picked up my LCR yesterday, on the drive home noticed a few things im not entirely happy with. Cant really complain though as I got it for a good price
Came from a Fabia vRS, so not used to petrol VAG engines yet!
Anyway, here goes
1. Temp gauge sits at 60 sitting on the motorway. Climbs up when you hit a hill, then cools down again going down the other side. Sits at 90 when driving about town.
2. Power noticeably drops off when you hit 5500rpm. Is this normal as the wastegate starts opening, or is it 'boost creep'. AFAIK, it still has the standard dump valve fitted, though the car has previously been remapped, though now removed. Still has a Forge induction kit and FMIC though. How do you tell if it has an uprated actuator spring fitted?
3. Only got 1 key with the car, and the metal loop on the end of it is broken off, so i cant attach it to my keys. Had a look through the key guide, but got confused as there is a lot of info to take in, and also some conflicting info... How easy is it to either swap the internals over from my key into another casing? Dont have the SKC either, so looks like it probably SEAT for a new key or 2, unless someone up in scotland has vag-com and vagtacho. WIll try posting in the vag-com section too...
4. Doesnt have cruise control. I retro-fitted it into my fabia using a kit from TPS, and had it activated. I assume its the same (switch and harness kit) for a leon too?
5. Gearchange is a bit sloppy. Is there anything common for wearing (bushes or cables etc)?
6. When you accelerate quickly, upto say 4000rpm, then back off before changing gear, there is a substancial 'jerk' when you back off the throttle. It may be totally normal, but like I said, not used to VAG engines, let alone turbo'd petrol engines. Just a bit annoying as I like to be a smooth driver but cant with this jerk
Any advice gratefully recieved
Anyway, here goes
maybe clean your throttle body?
