Binksy
Leon Cupra
Nov 27, 2009
89
Norwich
Reason I need to know this is that I'm unsure as mine was only on the car when I test drove it and I didn't get a great look at it. The garage insist that its the small undertray there are 2x undertrays for the the mk1 and I'm unsure what size its suppose to be. When adam cupra "a forum member" was round the other week he looked at the 2x types as i have a pic of them "but no scanner to upload them" anyway adam seems to think he has the bigger 1 just to be sure thought i would ask you all.
I have a Cupra 180t AUQ 2003
Any help part numbers or photos much appreciated thx.
on the diesels there are 3, one on each side and a big one in the middle which bolts on over the top
Oops sorry its the Cupra 180t
Yes the big 1 is 3 parts but my Cupra looks like it has the sides just not the bottom under tray :/ is why I'm confused to which 1 its suppose to have. I will try and get the pictures up of both asap which are from TPS and they said its the little 1 on all petrols and the big on diesels :confused: is it though ?.
Yours is correct your not missing anything ! I thought the same and had mine (03 180T) checked out, it is different to the diesel models.
Was on the car when i got it, looks similar to this
yep, thats the one. Serious bit of kit but rather costly for a mod you can't see.
According to the drawings I've seen, the petrol engines all have a short undertray that doesn't reach the sump, diesels have a longer tray that does go under the sump and gearbox, and LCR's have a long, flat tray with air ducts in it.
my lcr has that long 1 piece tray - covers pretty much the whole underside of the engine back to the rear of the subframe
how much are them then ?
as ive ground a few bumps out , think it was the centre section tho
Not sure diesel geek do them http://www.dieselgeek.com/servlet/Categories?category=Panzer+Skid+Plates
Found a thread with mine in it
The sump guard can be order with all the parts for around £170
I think the parts required as below but i will make sure later.
2x 1J0018885A Bracket £12.88
1x 1J0018930C Grille £77.29
3x 1J0018967A Bracket £2.73
3x 1J0018977A Buffer £1.14
7x N10070403 Bolt £0.95
7x N90810601 Cap nut £1.42
2x N90870401 Bolt £1.05
You will need a special tool King Klick T100 i think it was.It is for fitting some expanding rivets so the bracket can be attached.
It does hang low tho.
Thanks all seems so far its the little 1 on the petrols and TPS where right. I was sure I saw something bigger when i test drove it "maybe i did" but its not on the car now. O well looks like ill have to make do with the little 1 for now, that's if its on there lol else I'm asking them to put it back on :)
Nice under tray lee. I have already scrapped 1 hump to, had a m8 in there who's rather on the large side. Its not even lowered its all standard.
I'm interested in this.
What undertray(s) should a 2014 (Mk 3) Cupra DSG have?
Any parts sites with exploded diagrams or similar which might show what should be there?
