• Forum upgrade today 15th October from 3pm: Hi Guest. We are deploying an upgrade to the software that runs the forum today. It could take up to three hours. We're sorry but you're going to have to hold off on your CUPRA / SEAT fix while we work our magic. Thanks for your patience. Discussion here
Immobiliser issue?
Jan 11, 2005
680
Barnsley
I think you can disable the immobiliser through K+CAN Commander
I used K+CAN to get my SKC to add another key and seem to remember seeing something about disabling the immobiliser
Something worth trying is to disconnect the battery and remove the ECU to inspect for corrosion/water ingress.
Scimitar
62
Yea, i've read alot on these forums about people using K+CAN with varying degrees of success. If I have the SKC it opens a lot more options for me. If somehow the key is no longer coded to the car i hope to be able to re-code it.
Scimitar
62
PS, removing the ecu and opening it up was the first thing i did. Although coddoded on the outside, the inside was fine.
Jan 11, 2005
680
Barnsley
The best advice to get K+CAN to work is to boot the laptop with the cable already plugged in the usb and get the latest FTDI drivers. That seemed to let it work for me. If you have problems getting it to work let me know.
I got the SKC first attemp when the software was working. I then used vagcom to add the new key to the immobiliser. Vagcom wouldn't let me login using the SKC and I tracked it down to the car battery being below 12.5V. Once I'd figured that out, coding the new key took literally 2 mins.
Scimitar
62
Am I right in thinking you can code keys with K+CAN? I've also heard of something called VWTool.
Jan 11, 2005
680
Barnsley
You can apparently use both but I'd rather use vagcom/vcds. I used k+can purely to get the skc because I had problems getting it to work, I don't trust it to make any changes to the car. VCDS has proven to be a reliable interface so any changes I make are done that way.
That's just my opinion
samacus
112
i know you might have tried this but when i bought my reader coil my car didnt rocognise it at first but after having the battery out for a night the car was fine again
Scimitar
62
http://ajames.pulsewidth.org.uk/leon/extract_secret_key_code.html
Followed these instructions, get a message at the bottom saying "cannot connect to device turn off and on the ignition and try again". Sent the ecu to the ECU Doctor, said there was water ingress and did a load of work on the unit. Tried again, still won't start, still can't connect to device? Any last ideas before I take this perfectly working car (- the immobiliser) to the scrappy never to get another SEAT again? :p
p34ch3y
tastefully modified
Oct 17, 2005
2,879
cambs
had my ECU off to the ecu doctor three times,im unsure about there work!!:confused:
well my car is now off to the second place to try and be fixed,god dam i hope they get it sorted,it hasent been on the road scince july last year
off we go
fingers crossed for me people
Scimitar
62
Good luck mate. I'm fed up with spending money on this piece of junk, especially when I'm probably migrating in september. I think it's time to cut my losses! I probs won't touch a VAG car again.... Might go japanese....... or even french!
Jan 11, 2005
680
Barnsley
p34ch3y
tastefully modified
Oct 17, 2005
2,879
cambs
bloody hell mate you sound well hacked off
the thing that piss`s me off is that my car is a perfectly good car,new tyres all roud,new brakes,new susspention,hole new exhaust system,body work is fine no rust at all....yet! a chip or two but thats it,low millage,and it probly just a realy silly fault that no one can seem to find id hate to get rid of it because of this i would realy do me in,but if i do i will go jap as well
p34ch3y
tastefully modified
Oct 17, 2005
2,879
cambs
Can you communicate ok using vagcom? I think I had a similar problem when I was getting my SKC which was down to the dodgy chinese software. If you click on 'Identification' on the main K+Can Commander software what does it do?
with vag com i get{ engine controll module not found!}
Scimitar
62
Yea I've got new tyres, clutch, suspension etc. But enough is enough :p It's been nothing but trouble since I got it really.
Scimitar
62
Yea, seems to happen to me alot ;) Just gotta cut the losses sometimes though. I woulnd't want to inflict this vehicle on anyone else haha.
Scimitar
62
It does some stuff:p I have chinese software
