Jul 29, 2006
723
cumbria
www.facebook.com
After putting new forge TIP in on friday have been getting a fault code thrown up - N249 mechanical malfunction,thing is I've done the bypass so any ideas what it could be:shrug:
Have never had this fault code before though mate and have had the bypass done probably over 6 months ago,has just come since i replaced the TIP
I wouldn't worry about it; if it is bypassed it can't be doing anything bad! It is still electrically connected yes? Try cleaning the connection.
Right just been on a 2 hr either way trip to harrogate,the car feels like it has no boost at all,before i set off i reset everything with vag-com,when i returned i had the 17508- boost valve mechanical malfunction code again. Like i said i have done the N249 bypass and this fault code has only come up since friday when i put a forge TIP on.One thing i noticed was that my fuel consumtion actually went up by about 7-8 mpg.Is it likely to be a boost leak or anyone any other ideas,can't get a log run done for a day or two,thoughts anyone?
Have you checked all the connection around the TIP? DV? N75? vacuum hose from DV to inlet mani? If one of these has been dislodged it will throw up an error code like that and put you in limp mode (no boost).
yea checked that too mate,tested it and is holding the vacuum fine
How have you done the bypass? Have you used a new hose straight from one of the vacuum take off points on the inlet mani to the dv?
The bypass was done exactly as posted on here mate,its been fine for 6 months or so
okay; the reason I ask is that the fault code you are getting suggest the DV is not functioning properly. As the DV is controlled directly by this vacuum pipe it is this that is most likely at fault. If you detach the vacuum hose from the inlet manifold end and blow down it you can be certain there are no leaks in this part of the system.
ok mate will try that,but had a look around all that area and all seemed ok
