Best dump valve for fr tfsi on experience
kezFR07
now with ko4 power
Jun 15, 2008
871
yorkshire
Hi I'm looking at getting a dump valve for the car but I'm unsure which one to get and wondered if anyone could give me advice based on experiance. I'm not lookin to spend a fortune though maybe up to £75 or something. :)
warren_cox
Back from the dead
for £75 (or less), the best Diverter Valve (?) you are going to find is probably this:
The revision D OEM unit. That said, as yours is located round the back of the bay, will this fit Dan?
DanGB
Who need's a Diesel....
Feb 12, 2006
3,772
London
Im sure i read this wont fit the k03, but They have discontinued the last rubber diaphram revision.
The Piston one above one is £50.52 excluding any discount.
robdf2
Yellow is the best
Feb 21, 2006
3,605
location , location
what do you what a dump valve for ?
are you after the whooshy noise or because your old one is faulty?
May 25, 2008
1,919
S.Wales
www.seatcupra.net
okay basically you want the "SPACER" excuse the caps...anyways you can pick one up from Forge around 50.
The revision D OEM unit. Im using this exact D on my TFSI now not had a problem but yea if you want a woosh noise all you need is a spacer.
Oct 17, 2006
2,141
Mid Wales
Nope - the spacer just allows a bit of the boost to escape making the woosh and recirculates the rest.
VAG turbos require a fully recirculating system, so technically you'd be doing the engine better to keep it fully recirculating
warren_cox
Back from the dead
Difference between the two DV's (Rev D on the LEFT):
The orange diaphragm in here gets split over time:
Here is a pic of the Rev.D head on:
I'm running stage 2+ with Rev.D and no probs at all.
I'm not sure how successfully the Forge split ring runs. Is it hard to set up?
kezFR07
now with ko4 power
Jun 15, 2008
871
yorkshire
thanks for all your help lads much appreciated :) well I'm after that whoosh haha so I guess il get the spacer one. Il get some pics info etc when it's installed !
beeko85
322
Bangor, N.I
if you want a whooosh noise get a neuspeed p-flo intanke.... when you give it the gas then let off and then hit the gas again you get a noise that sounds like turbo flutter/ chatter.
http://www.youtube.com/watch?v=DQk3xi-lDs0
http://www.youtube.com/watch?v=KR7dibG45IM&feature=related
http://www.youtube.com/watch?v=Mz0-wFyjieM&feature=related
That sounds amazing, I ordered the itg cai from awesome this week. Searched for a few vids on youtube of it, sounds something similar, not quite as loud as that though
