techie
Skoda Techie
Mar 22, 2003
5,438
Worcs
Hello peeps.
Whats the piston size on the master cylinder on the 1.8T Cupra?
22mm?
Ross
Hi!
I think its 23mm! (i think all ABS 1's are) its also a subbie one i've just fitted one to my mk2 golf (if thats what you had in mind) so it should clear the 20v cylinder head no problem :p
You are a star!
Built this up today at work ;)
Together with the 9" servo it should work well.
Thats the chap!!!!!!
the front of the res rubs slightly on the suspension turret so i ground a couple of mm off to help but it still fits, take it this is for a hydro pedal box etc...
Can't answer that thb (although i heard 312mm were the dogs bits lol)
Just remember it'll not be straight forward swapping it,i had big problems removing the servo,its held in the back of the pedal by a white clip (ball on the end of servo rod,not the same as a golf) i had to break it to get it off and SEAT don't have the part listed so it probably comes as part of the whole pedal ( 1 way fit only for safety i presume)
i could take some pics to show you sometime if you like,just PM me!
You can get the plastic clip, just look up the part number on a MK3 Golf, same clip.
I may well mod the turret a little if needs be as its kinda in a state where it could be done.
But yes i am converting to hydraulic but was also looking for a better clearance as mentioned by yourself. The chap who built the car ground a bit off the original master cylinder which looked awful.
Is it the cylinder body or the reservoir that is the issue?
i know this thread is old, does anyone have the part number for this master cylinder?
its bosch and 0204024054 this is the number but its hard to find on the net
arr cheers for that.. I guess that is the Bosch part number? Do you have the VW/Seat Part number. What does this MC come off (Car, year etc)?
do you know if:
Is it a 23mm?
Does it have 2 holes or 4?
Ben
Edit:
meteor.com.ua/catalogue/item/id/BO+0204024054
I believe it is: 6K2611019E
It is £243 from vw!!!!!!!!!!!!!!
do you know if:
Is it a 23mm?
Ben
Edit:
its 23.8mm 2 ports left hand side its a stubbie master cylinder.. and its from a mk3 ibiza cupra 1.8 20vt 2000 - 2002 not sure what else its on ..
