R4cup
Beef NO Burger
Jul 28, 2006
1,749
In the garage
Hi guys im due to relocate my DV pretty soon & was wondering if it would be ok to use the metal T-piece below rather than the silicone one?
yea its fie mate
theres a thread on here some where that myki had done about this
Will work fine although you will need a bit of 25mm silicone so your able to join the d/v to the T piece...plus 2 more hose clips..doesnt it work out more expensive or is it a certain "look" your going for.?
Im not 100% sure which would be the cheapest but it would be nice to see a pic's of a metal T piece being used anyone.........
:funk: i look forward to seeing guide as i would like to carry the relocating out this weekend.
You dont need a guide its really easy to do.
Just take off the dirty old original hose and replace it with the new shiny one that youve made.
Take it for a test drive and have a face like this for a while...:D
Got all the bits bar 25mm of flexi silicone which im finding hard to locate in red.........
Once i do & fit i shall post pics:)
Im planning on using the original pipe that comes off the inlet to relocate, ive already cut my metal T-piece down but there still seems to be a kink in the silicone bend off the inlet so im looking to chop so of the silicone off. I sure someone on here must have done this already :confused:
I chopped mine in 2 pieces and put the t-piece in between
mine wasnt a standard hose though so may have been a different angle (never seen how the standard hose goes)
On the original pipe from off the inlet, it does have a part what goes skinny, I cut into mine just before that and I also put a metal t piece in mine too... Works perfect no issues at all!.
I did the same as myki, 25mm sillcone t piece then replaced old hose (that links inlet manifold to intercooler) with 2x 90deg silcone hoses and then a bit of 70mm striaght stainless tube to join it all up! didnt think you would be able to make standard hose fit as the moulded bends init?
Can u remember how long your t-piece was? do u have any pics?
I really want to do this later but dont wanna F$%K up like i usually do lol
Mission complete & well worth doing. My dumpers sounds crissssssper & louder :D
Oh & before anyone starts my t.i.p is on order.... i know what u guys are like lol
where did you get that flexi pipe from that goes from TIP to DV?
I have my T piece just not that pipe and need it in black
Also what is that pipe you attach your T piece to I have seen some with silicon ones
On this picture of the forge kit it has the DV in it
Can you just buy that pipe?
Looking good
Only thing i suggest is maybe cutting a small amount off the flexi pipe
Think i cut about 20cm off
Flexi pipe was off ebay £27 i think inc p&p
Im not too sure what your trying to say sorry.... do u have a metal t-piece?
Looking good
Yes i was thinking that from looking at other members pics on here.
Cant wait to fit t.i.p.....might pay a mate though as i dont want to bleed lol
