ye done it as seen in my RR , bet shels aint been done since forever :)
the car wash people by work was like you taking the pi$$ when she gave the megane in
i also felt embaraced when i took the megane up xmas time to asdas , on a rainy day the boys up ther do it for £2.50 , was the hardest they worked for that much money ,
:cartman: before christmas was the last time shels car was done :cartman:
Just changed the oil in my car using a 6L Pela Pump
nor this clean anymore
amazing - took the sump plug out after and there was not even a trickle.
also using this was able to suck all the oil out of the filter housing and the oil cooler
so happy now and then I also reattatched the Undercover - Nice and secure now :D
hopefully a straight swap - will do when I fit the Cruise control kit
Half term is coming :D
Quite a few people have done that, and from what I've seen it is a simple straight swap apparently.
Good idea to get it when you're doing cruise control too. Killing two birds with one stone ;)
My passenger footwell is wet again [:@] - checked earlier even more today need to sort this - going to use some microfibre cloths to soak up as much as possible and then use a moisture trap to draw in other moisture will posiibly leave the heating on high and aimed at the footwell see how this works
thinking of getting another pollen filter to try
think I may have used an Aftermarket - non OEM one last time:censored:
