aaronbromley
TDISport.com Owner
Nov 25, 2004
337
Lincolnshire
www.tdisport.com
Hey guys and girls,
I was driving out of my close last night turning the wheel when i noticed a sound which i can only describe as a "scraping" sound. It was too dark last night to be able to see what was wrong and i assumed it was a piece of plastic catching on the wheel, so i had a look this-morning and found this:
file.php
It looks light my front right spring is broken (as you can see the coils are too close together at the top).
Pretty well covered on here, I would think you wil also need the top mount and bearing replaced.
I would say the best way is to remove the suspension strut & inspect further.
A month or two back i had my car Serviced by the stealers. They diagnosed my car to have both front coil springs to be snapped. After further inspection & replacement was taken on by myself I found only one of the coil springs snapped.
As mentioned Replacing the Top mounts is advised & this something I should of done in my own scenario.
After a recent conference with a Coil spring producer, it was mentioned that its advised to change the springs in pairs (this could be seen as a method to increase their revenue). I myself changed both.
All I will say is that as long as you have the right experience, the right tools & information you could take on the job yourself.
One Guide which I found helpful was the following:
http://www.seat-ibiza-mk4.co.uk/ibiza_front_shock_absorber_change.htm
Best of luck.
Ash
