The Sportlines will give you around a 40mm/25mm drop on the FR. You could always fit the springs and then change the dampers down the line if you need to.
Damian @ DPM Performance
I've noticed that the Eibach sportlines give around 20mm on the front and 30mm on the back of a cupra why is this, Is it because the back end is higher as standard? The H&R give 30mm all round on the cupra so not sure which will look better, Has anyone fitted the H&R springs?
The Sportline's give 50mm front and 35mm rear (about 35mm front and 20mm rear on a Cupra).
The Sportlines do give a more nose down stance so the H&R's would be a more even level drop.
id be extremely tempted to try the bilstein dampers if i wee in your shoes.
think im gonna give them a go, the sportlines ended up dropin the car more than i thought, must be close to 50mm for sure, so i really doubt the standard dampers will last that long
Thanks again Damian, do you think the H&R's will be alot stiffer than the sportlines and prokit?
