I would much prefer to pay the £180, but id like to have red springs :(
Dilemma :confused::doh:
@Adam
Is an uprated ARB or even shorter droplinks essential? because id hate to budget for the coiloevers then find i need to spend another load of £££ for bits to make it work.
Just wondering if anyone has these or knows anything about these.
There are 2 versions.
Redline (£280)
Blueline(£190)
They seem too cheap to be true so i just want to know if anyones using or used them before.
I ordered a set of the blue ones from Damien the other week, there getting fitted on saturday so will let you know what there like.
Alright cool, so im looking at about £350 all in for the blueline ones with an uprated ARB :blink:
Might just leave it slightly higher for a while then lol.
The ride is always slightly stiffer with coilovers but I wouldn;t say they were harsh.
Damian @ DPM Performance
Damien i got the blue ones from you the other week and there getting fitted today, but ive been reading a few threads and is it right that to adjust the rears you have to unbolt the shock first? If so which many have said is a PITA are the JOM plus ones better as from the pics the rears look the same as the fronts with the shock inside the spring so easier to adjust?
you can adjust the rears for height on the car, just screw the adjuster up and down....
the picture you see is universal, the shocks are independant to the strut.
I'd say yes you need to unbolt the shock......well I do on mine as there under to much tension to adjust.
Fronts are fine you can adjust without taking the wheel off.
Not one to argue but there excatly the same as mine and mine you do :cartman:
In principle you don't but in reality you do......maybe there different :)
