My car is borked - New CAT Back system needed
Mat Lock
Carless Wonder
May 24, 2007
626
Purley, Surrey
www.mat-lock.net
:censored::censored::ban:
Driving down to Bath today and got to Reading before my temp gauge decided to rocket in to the red. The exhaust or something underneath my seat is making a major knocking sound. It also is blowing harder than a bangkok wh*re !!
Funnily enough though when I limped back to Croydon doing 50mph the temps were fine and the mpg was averaging 41mpg.
So I think it's not as bad as it sounds but have to take it down the garage to get checked/welded/new exhaust.
beezertart
**MAYHEM**
Sep 11, 2007
1,259
beyond the sun
dad had a custom made system put on his kit car for around £280 at RSR at Factory Lane, Croydon although they have branches at South Croydon,Fiveways etc..
kwik-****,what did they show you?
beezertart
**MAYHEM**
Sep 11, 2007
1,259
beyond the sun
if you do get any response from a wanted ad, make sure you get pics of the weld joins....i got a 20vt to replace mine and it was in a worse state than the one i was taking off! that was only fubard along the seam of the box, the one i bought was fooked on all the joins!
Mat Lock
Carless Wonder
May 24, 2007
626
Purley, Surrey
www.mat-lock.net
Yeah, I saw the underneath when I took it to Kwik Fit, it had already been welded a few times, which is why it was so corroded this time. Literally has just split, which is what the knocking is. The pipe after the cat is bouncing around now it isn't connected to the cat. The rest of the pipe is in pretty bad condition too.
i wouldn't even know if the manifold end is alright either.
vngtx
Needs a whole new system fitted. Kwik-Fit quote between £450 and £550
How much is a custom made ??
dont listen to them!! they said i needed a new back box and center pipe just cos the clamp was loose.
Mat Lock
Carless Wonder
May 24, 2007
626
Purley, Surrey
www.mat-lock.net
No, I went under the car with them and it's nasty !
I will try and get a picture of the car, while I roll on the floor underneath ! I need a cigarette anyway...of course I won't smoke while I am under the car, or you might see me on the news later.
suj
Wheel Connoisseur
Jan 1, 2009
5,808
Birmingham
get a mk3 exhaust matt, its the best one, looks the part, sounds the part, and kinda OEM in a sense :p
