how much you pay mate and how long take to get them sent over?
looking good, whens your car going to have parts fitted?
$209 dollar plus $37 shipping, i had them within a week.It should be going in in the next week or 2, i'm not gonna rush it as i want it done right.
Also do me a favour, when you get you manifold bolt it up to the turbo, i did mine tonight and it is way to close to the charge side outlet on the turbo, way to close! i emailed 034 over pic's, might just need to smooth abit off the side of the mani, i will keep you updated to there response, just thought i'd mention it as you will be getting the same mani, just from INA instead.
ok mate cheers,
will soeak to my mapper reerence the injectors and if need to get some then will, stick up a pic of how close you think it looks and i will have a look and see if mines same when i get it ,
ok mate cheers,
You WILL need need injectors, your old ones will be maxed out.Check out Bill's Hybrid install and you will see the injectors on his S3 were not cutting the mustard from the start.If you decide to run them anyway you can log the duty cycle and use this calcutator to see if they are maxed out, ideally you don;t want to go over 85% duty cycle.
http://www.stealth316.com/2-calc-idc.htm
Here are the pic's, its to close for comfort IMO
wow that is close, have you got a response yet? and would you still be able to attach the turbo to manifold and manifold to head, and i them injectors you brought have you teated to see if they fit?
I got a response yes, but i am working on getting a better one.No those injectors havent had a test fitting as i have nothing to fit them too, but ECS say the fit 225 and all the other VW forums recognise them as a decent injector.
lol and your reply was ??? no i guess lol
Basically, but i don't want to get all crazy with them, i realise with no matter what products are out there you will always get a % that have defects, however i do expect customer service so we will see how it goes, you never know i might just grind the fuc$ker there not that expensive really.
Where did you order the injectors from?
when ine come i will see if i have the same sort of closeness ;) and i dont mind gringing as ling as keeps manifold warrenty, might even use exhaust wrap on that part of the turbo, i have ordered mine through ina
I only plan to heat wrap with outlet from the compressor wheel housing and thats so the charge temps are kept down and the housing is protected from the manifold.
How much was INA for the injectors if you don't mind me asking?
hi mate was 550 for a coated one, i got some thermotec exhaust wrap so will do same if have the same issue, and what have you changed about your wmi? im going to be fitting mine soon, :)
