hi mate yeah i got everything just waiting on clutch being balanced to crank then when go hoe at the weekend will pick up my high flow mani and injectors.
also brought some methanol today, got about 13 litres and been advised to start with a 20% only methanol mix for starters.
love the fact will increse the octane rating :) not sure if should run the methanol for cooling or to advance the ignition, :)
I run 49/50, i got 8 degress of timing from the WMI before we hit MBT, i didn't see any increase in BHP until i got the car tuned for the WMI.It will greatly help with your EGT's and whom ever is doing your Hybrid tune will/should take this into account.
Not sure if i need all this timing when i get the new setup going(next week!!)
you going to be having your turbo mani and conrods fitted next week :) the race is defo on lol, will stick some pics of mine up when i get home :)
i spoke to dpj today and he said to start with a 20% mix :) will see how i get on with this .
Yeah, should be finished tuesday and getting the first tuning session done wednesday, unfortunately i need to leave the country thursday so i am doubtful that we will get her fully tuned in 1day.Still i am going to the USA so i might pick up a clutch or some sort of fancy mod for the car, maybe even a WOT box.
P.S i got mine tuned running a 49/50 mix, thats why i have stuck with it.
you got some pics ;) did you grind any off your mani cant remmeber if said you did?
what figure you aiming for and hows the new injectors?
Yeah, i skimmed about 1mm off it and then clocked the turbo about 2mm.There is a good gap there now.
The new injectors are ok, the ECU is having a micky fit trying to figure out whats going on, my fuel trims are -24.1%:lol: Still its doing it job well trying to lean the mix out.
I'll get pics up later for you.
