As title. I say 20mm as I wouldn't go any bigger.
Also I will be keep the same on each corner as per previous threads recommend.
Is it ok on the wheel bearings?
20mm is excessive for the front..
why?
hubcentric is going more than 8mm, and if using hubcentric or bolt on spacers, there should be no extra load on the bolts than std, they still clamp the wheels on
I have 20mm on rear, longer wheel bolts are needed, so no stress is applied.
what significance do you think this will have on the overall life of your wheel bearings, I know upgrades come at a cost sometimes, but just wondered if you had a idea of how long it might reduce the life by?
why?
