lol, at the next major RR event i'm going to bundle you into my lcr and give you an education in hybrid power, you'll need a nappy though as you'll **** yourself in delight as we embrace one Gforce after another in a man love type of way and then you'll lite me a cigarette telling me how good the ride was and it did it for you. later i'll see you ringing Bill to book yourself in for the hybrid treatment.Noooooo not a failbryid
If i'm not mistaken Danny, your actuator box has a green sticker on it which indicates it came with a green spring which is the same as the stock one which is an actuator operating range of 5 -9 psi.![]()
Its T2 danny, but relax. I'll refit my green spring today to show you what its capable of. The work is in fitting the actuator bracket. Only takes me 15mins to take the actual actuator off to replace springs etc.Is my actuator a T2 or T3?
can't Believe ive fitted it and its on a stock pissing spring..
51mm od danny
check with your mapper of choice on this actuator crack pressure, or use mbc/ebc to control the spike.
tig, if you have ac on your tig
