nice mate, Im slowly coming round to gloss black mirrors, the calipers look spot on
Well its been on the rollers again today and did better power with the torque the BHP didn't go up any more on peak power. but still pulls like a train.
If you look at the first Run in Blue ive got NGK plugs and did 270 bhp at the clutch
2 mins later after changing my spark plugs for http://www.pulstar.com/
i ran my car again, second run in red did 6 bhp better and the final run in green made 7 bhp better. so with the new gasket and cold air feed, the torque made 20 lb ft better than last time.
and showed that them spark plugs weren't just a placebo and did make power
An updates John since your REVO upgrade.
Im still running these plugs and dont have any issue with them they are Expensive tho. got them thru work but we cant get them any more.Think there is some on e bay.
Carl - Car feels better and pulls harder low down more boost, had issues at first with bad fuel so changed that out and new fuel filter. its still running about the same power are APR . but we knew the APR map was very good with my car. its doing 283 bhp. and 364 lb ft now i will print a graph off at work and get it up . will try and show APR runs and REVO runs .
Are you still running these plugs? Are they still OK? I am looking for some for a 1.8T BAM code, could you get me a part number & price.
Thanks Richard
Hi John,
Having done a bit of digging on the net, I think I might have found the product code required, which is perhaps used:
Pulstar Pulse Plugs - BE1-I-Series Iridium.
Sorry for posting but thought it might help Richard and others; just hope I'm right...
Thanks,
James![]()
Thanks for that, they do not list them for my engine code on there website.
Richard
I know they don't but I've bought some today with the code be1-i to see whether they fit or not. They appear to, from reading up, to be the right fitment when making comparisons with the NGK plugs that I have at the moment, but time will tell....
And I'm sure John might be able to shed some light on the matter.
James![]()
