SEATgod
Hello,
It is a legality to have self levelling and headlight washers on Xenon's....
If you fit self levelling (front and rear axle sensors) you will need an upgraded On Board Voltage control unit (PR code for Xenons) and you will need a headlight control module!
You will also need to upgrade the wiring between on board voltage and the Xenons as the igniters carry a greater amp load.....fire anyone??...oh dont forget to install the correct rating fuse either!
Plus the ball ache of fitting headlight washers!
Xenons aren't just a bolt on part!
Regards,
Regards,
