Not yet, Just tried adding you on MSN btw. Could do with some help.
Ahh right. Thanks anyway Scott, I've got an idea of what I might do to fix it, just hope it's as easy as the plan.
Not seen your old car btw, bit of a legend that car.
Scott, when you were doing ur B pillars in Glossy vinyl, did you remove them to do it? or did u do them as they were on the car?
I'm doing my pillars in gloss vinyl too, ever since seeing scotts i thought it looked mint. shame the gloss vinyl can be a pain to apply
The pillars on my 5 door seem pretty hard to remove, not sure if they're different to the 3 door? if I can remove mine i'm def going to do it, should make vinyling it much easier
If you get them off let us know as I'd like to do mine when the weather gets better.
.G.
Sent from my HTC Hero using Tapatalk
I bought new ones, painted them and fitted them on my old White one. Easiest way, you ruin all the original clips when pulling them out and the pillars themselves can get damaged pretty easy. They arnt expensive either.
