Which gearbox have you used for the swap? Having 6 gears would be nice! Top work on your car, keep going! :D
Is a custom gearbox. Mixing the housing of the 6 speed 6L TDI and the internals of a 6 speed 1M 20VT. Because the complet 1M gearbox is not plug&play. The engine mounts are not in the same place.
Today the engine has roared again !!!
Video : http://www.youtube.com/watch?v=ZNL3rhiETZs
Finalizing details…
The new PCR pipe. Aluminium 50 mm. Ø
My broken brake disc
And the new one. With Galfer Sport 1055 pads.
Finalizing some things to make the first test run…
Without dashboard xD
Waiting his first full tank of 98o
38 liters, 54 euros
The car works very fine. Just need some small adjustments.
I'm very happy. Tomorrow will be continue the work...
Also interested about the catch can as i am about to get one for my Big Turbo project.
I am thinking of installing mine in the area where the SAI was as i will be removing it.
That is next to the oil dip stick.
Hi! Amazin project, very nice build! Loking forward to follow it
But im wondering how you changed the colour in the old tdi speedo? Numbers from red to white, i was (untill now) thinking about change to birba racing white, but this you have done just looks killer :)
Could you please explain the operation?
Jon
Stunning car mate i like the wheels from the first pics
Where you going to mount the oil catch can?
I don't know yet where we will install the oil cath can. Next week we will have the answer hehe
Changing the SMD leds of the speedo, for other with white light.
Here you will find a small DIY thread.
http://www.seatibiza.net/foro/showthread.php?t=37727
Where to buy the leds.
http://stores.ebay.es:80/HKJE-Led-Lamp-Center/_i.html?_fsub=17&_sc=1&_sop=1
All of this wires are the wiring for the four new gauges
Oil Temp, Oil Press, Water Temp, Boost
Fixing them behind the dashboard
Filter to protect the digital boost sensor
The boost gauge sensor
And the wiring passed to the engine bay
Coming soon more...
First of all. One pic of our cars (me and my wife. she have a Cupra TDI '04)
ECS Magnetic Drain Plug
Super Pro bushes
OEM Bush + Powerflex insert (It's a ****. Works fine, but also breaks OEM )
And here the Super Pro installed
Are those wheels team dynamics pro race 3's? What sizes are they and do they fit over the AP brakes as im looking to order a set but no sure what offset :(
I have the super pro dogbone in my car which rating did you go for? Mines is 80K and i get a bit of vibration
No, the wheels are Compomotive MO5 1776 - 7,5"x17" ET35
My dogbone is the 70K. Because I had mounted on the diesel engine. It's normal some vibration if you have the 80K (Competition use)
This bush can cause engine vibration to be transmitted inside the car
Thanks for links, good job -again! But still how did you then make the white background light up in white? My pd100 is all sad black and red, so this could really help alot :)
Maybe i could buy your speedo? :p
