Hi Tom, just a quick one...did you fit your 3" TIP by yourself?
If so, was it an easy job?
Hi Jason,
AmD fitted mine when I was down there as it turned up the day before, so it was convenient!
They said the adaptor plate to the turbo was a very tight fit and you think it won't go in but it will..
I had my Forge tip out before that was simple enough. The main difference is the adaptor and using sealant on it or loctite think Coops said. Once your past that it's just another TIP but bigger!
