Ok this is how it now looks finished product
Yea iv been thinking of one of those how could i tidy up my boost pipes
1st:get rid of the n249
2nd:boost guage vac hose take from the green nipple on the side that way hose is more out of the way
3rd: the vac hose from the inlet manifold run it in the injector wire tray like this
that should tidy up the hoses
Cant get rid of the N249 as im not 100% confident putting resistors in.
Ill change the boost gauge asap , and ill run the vac hose through the wire tray thanks for this
getting my forge tip in the next couple of weeks then thinking of Re-routing my intercooler pipes down the wing , If I done this do you think I should spray the pipes black like I have my charge pipe?
think its 8mm hose there is plenty on ebay get some nice blue covers to go on the end, 5min job to swap the fuel lines over, as for the n249 get it mapped out
Or you could trace the wiring through the loom And hide it out if the way in stead of removing it like I have for mine as well as the carbon canister sensor. No fault codes! Better than resistoring everything as they get hot in shrink wrap and sometimes fail spiking your ecu , not good!
Not sure about following it back up the loom not confident to do that when/if I went hybrid could it be mapped out then?
gonna look for braided fuel lines now:)
Soz to be a pain, But do you have a link for the blue covers as I cant find them on the bay.
Iv found some fuel lines, Not sure if there the right ones though any one got a link to both.
