Chassis Type: 1M - Seat Leon
Scan: 01,02,03,08,15,17,19,22,35,46,56
Address 01 -------------------------------------------------------
Controller: 1ML 906 032 A
Component: 1.8l R4/5VT 0001
Coding: 10510
Shop #: WSC 66565
VSSZZZ1MZ4R118615 SEZ7Z0D2455934
No fault code found.
Address 03 -------------------------------------------------------
Controller: 8N0 907 379 G
Component: ESP FRONT MK60 0101
Coding: 0019469
Shop #: WSC 00001
3 Faults Found:
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
00287 - ABS Wheel Speed Sensor: Rear Right (G44)
003 - Mechanical Failure - Intermittent
00290 - ABS Wheel Speed Sensor: Rear Left (G46)
Address 08 -------------------------------------------------------
Controller: 1M0 820 043 E
Component: 1M-CLIMATRO
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 1M0 920 922 F
Component: KOMBI+WEGFAHRSP VDO V05
Coding: 05424
Shop #: WSC 00000
3 Faults Found:
00562 - Sensor for Oil Level/Temperature (G266)
29-10 - Short to Ground - Intermittent
27-10 - Implausible Signal - Intermittent
49-10 - No Communications - Intermittent
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 06402
1 Fault Found:
Address 46 -------------------------------------------------------
Controller: 1C0 959 799 F
Component: A7 Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 06402
1 Fault Found:
00931 - Locking Module for Central Locking: Rear Right (F223)
27-00 - Implausible Signal
End -------------------------------------------------------
