No unfortunatly(due to s*** weather), hopefully getting it laquered up this weekend :). I found the cause of bubbling anyway, was the points id fillered. sanded and touched up.
Should have the main body of the car out to do the bumpers by next week hopefully :)
finally got some good weather and was warm enough to clear coat :)...... will hopefully have it out of the garage this weekend and will take some pics before and after wetsand !
Just remember when you polish it up after cutting it back make sure that mop head is dead clean and has no grit in it. I would recommend claying the car before machine polishing and I had loads of shite in my paint work/ in the mop head and it's now left me with swirled paintwork, meaning I have to either detail it or get it detailed (which my mate is doing for me this weekend :D)
I have ordered brand new machine heads , a meguiers wool light cutting and a buffing head too. will G60 compound be alright ? (also im using meguiars 3000 grit), so far so good , got bits of dust here and there , hopefully the wetsand and flatting will remove them I guess ?
While Ive been waiting ... I thought id have ago at carbon wrap. Did my front badge in 3m Vinyl
Ive never done it before.... hopefully it wont take the 4 painful months of waiting for weather haha
Don't count your chickens lol, not as easy as you think, and when you do it and then rinse off the car, let it dry and you'll look at it in horror because it will be matt, don't worry though it will shine up :). Just make make sure that there's no rubbish left on the paint work or it will soon be in it after polishing! Another thing I found was that when I did it inside my tent I couldn't actually see the dirt on the car and thought it was clean, this contributed to the swirls and a hell of a load more work afterwards.
Not criticising or anything just don't want anyone to make the same mistake as me and find that it takes 300% more work than is needed.
As long as it looks decent Im not fussed. took masking off today. was looking really good. Will upload pics tommoz
nice weather for once so I finally got it out. Needs a few areas rubbing down still but its pretty damn good for a garage diy job :D
I have found 4 spots that need more rubbing down so i ordered some 2k grit as 3k was well too fine haha. You mean shots of it when I got it ?
2000 wet and dry is what you should go over it with anyway lol, especially if you did yours in a garage! I bought 4000 as well which is like a kind of finishing paper, I got them with sponge backs as pads. Yeah I meant some side-by-side pictures.
OK ill put some up later. My car has a shine to it but I think I can get more out of it. Ive used some g6 and a wool cutting pad so far.... should I rego over the car again in 2000 or just polish it again with the g6 compound ?
top pic was done with a phone so fading cant be seen, although fresh coat is a much stronger yellow
Using a cutting compound like G6 is about the same as going over the car with 4000 grit. I went over mine once with 2000 grit not pushing heavily. Then same with 4000 grit. It's hard to exlain and I wouldn't want to say to you yeah go over it again and find you end up sanding all the paint off.... how many coats of base and lacquer did you use?
