Yeah it was probably roasting but what difference does it make really:shrug: there designed to work in those conditions and if there not they have no business in an engine bay.
i dont believe the spring is being effected by heat... its a formed spring and engine temps are no where near what they would be tempered at...
BUT
I do think springs once compressed will relax after initial use and settle.. which is the more likely cause for change to me
that video you posted above is exactly what I was describing to you... Great vid.. comfirms what happens when the nozzles too outboard of the hole its sat in.. The spray cone which is usually less than 90 degrees (and varies with manufacturer I might add) could catch the hole on the way out if not flush with the pipe ID, cause drop out.
I seen those Rob, i wanted something that matched the shape of the existing TB so it didn't look out of place(im shallow, lol) and i can get mine made for less than that locally.
Still good to know.Thanks.
P.S Just looking at that spacer again and that rubber seal won't last 5minutes of methanol gets near it!
BUT
Bill i modified the plate again so after 5mm of thread depth it is then tapered off at a 45c angle [B)]
Pheonominal Build and Phenominal car mate!
Some serious work gone into this and its certainly paid off!
Beautiful
Thanks Alex, if you think mine is good you should check out RobDon's;)
1/8" npt taper threads anyhow, so depending on how it was tapped will depend on how deep it ends up
someone going to be able to do a 45 degree chamfer on an internal bore face?
Bill the guy can build practically anything you want, he can only be described as a seriously talented, he has a build thread over on Club GTI where he is rebuilding an engine, but most of the parts for the engine he has fabricated himself.
If you have an hour spare, this is well work a read
http://www.clubgti.com/forum/showthread.php?t=205299
I have just spent a good five or six hours reading the whole of that thread, its absolutely incredible the skills that guys got. Im in shock!
brianG - I am familiar with his work..
i luv the way he "just casts stuff" at will... amazing
WMI nozzle mount
Evening all,
No updates for a week, i was away:( I arrived back today to see my WMI nozzle mount had arrived.Brian.G as expected did a cracking job on this spacer, it just needs to be polished up.
I really don't know why i didn't do this before, the new mounting location should eliminate Water/meth ingress to the throttle body, in addition to this 100% better atomisation is achieved( videos below)
The atomisation achieved from the Devils own mount is absolutely crap, if i had have see this before i would have not installed it into a silicon pipe.
Here are some picture and at the end 2 videos of the better atomisation achieved with the new mounting spacer Vs the crap atomisation achieved with the Devils own mount, shocking TBO.
2 videos, before/after.
http://www.youtube.com/watch?v=7A2X5-SmKgA&feature=mfu_in_order&list=UL
http://www.youtube.com/watch?v=a9BN7a8mXQM&feature=BFa&list=ULrL2QP0or_Vo&index=7
this car is fooking awsome the best lcr on here by far i enjoy reading your thread and the will to keep up with it and paitent you have with it is a credit to you mate.
great work robbie, as wayne said your a credit to your self, but also you are helping others who want to do the same thing. i have learned a few tricks from you now, so it just shows you are a important member on this forum. and again as wayne said your car is one of the best here. keep up the good work m8.
I was shocked at how bad the silicone hose adapter performed too, just lets water/meth pour into the hose ... really bad!
So true, i never seen it in action untill i did the test, its a very poor solution.
Cheers Wayne
Cheers Sam, as said the idea is to give other peeps info and help them out, SCN is a great resource, so i am just glad to be contributing to it.
I am very happy with my latest little mod, so far it works great.
thats good to hear m8. bit of topic but i expect you know the answer to this question. is a rocker cover from a 180 lc the same as our lcr rocker cover
Robbie, so glad to be of help, and that the cast spacer works as it should, I cant believe how bad the atomisation, or lack of was with the old setup, enjoy, and all the best,
Brian.G
