If you just bolt in the cage as it is, you are doing nothing but adding extra weight to the car. You need to pre-tension the cage as you fit it, so that the cage is forcibly pushing against your chassis and stiffening it. It can be done with ratchet straps, blocks of wood, bottle jacks, or any way you see fit.
