Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
Vtec > everything else.
All this talk about torque means it's time to dust off the old lecture again.
Power(bhp)=Torque(lb-ft) x rpm/5252
If you have power, you have torque. No way around it.
Torque is a measure of the amount of push the charge in the cylinder is giving to the crankshaft. In technical terms this is BMEP (Brake Mean Effective Pressure) - a measure of the pressure generated in the cylinder head when the fuel-air charge burns. How much bang it makes, if you like.
This is why larger displacement = more "urge" at low revs, which is often erroneously called "torque", as if that were all it was. More charge = bigger bangs, you see.
The "BHp" figure on the spec sheet is found at the top end of the rev range (notice that rpm is a factor in the equation above). As long as the torque, i.e. the bang from the fuel/air mixture burning in the cylinder, is sustained, peak rpm is limited by mechanical factors, often valve bounce.
In a petrol car, rpm can be increased to ridiculous levels (20,000 or more in F1 engines) provided all the whirling bits are balanced very well, the gas flow all through the engine is good and the ignition can keep up. Increasing rpm is a prime factor in getting more rated power out of petrol engines. Of course this means you have to wring its neck to get that power and go around sounding like a banshee out of hell.
Vtec helps a small-displacement car get to a bigger max-bhp figure by changing to a power-optimised cam profile at high rpm. In order to make use of it you have to be high in the rev range, but that's true of any engine - to get that max-bhp figure you have to be revving as high as you can get.
Turbocharging increases the amount of charge in the cylinder, so making a bigger bang. It doesn't work so well at very low revs, but can be arranged to provide max torque through a large part of the rev range. An LC or LCR makes practically the same torque from 2000 rpm up to 6000 - the ECU limits the turbo boost so as not to overstress the engine. But it's the bigger bang that increases the max-bhp figure, and a turbocharged engine (or a supercharged one, for that) has the bigger bang.
By the way, Applemobile is playing at being a troll.![]()
very very good All this talk about torque means it's time to dust off the old lecture again.
Power = Torque aint exactly right.
The wife had a 2008 Yaris 1.4 D4D putting out just 90bhp but 140lbs/ft or torque. The RX8 i had was putting out 231bhp but just 156lbs/ft so loads more power but not much more torque. Compared with the Cupra 20VT i had putting out 180bhp and 179lbs/ft so less power but more torque than the RX8.
The friend in question is fairly respected tbh. If anyone knows of him it was Richard Astley? Tbh I would expect him to let me down or tell a lie.
You know him do you? The guy knows what he is talking about, I just rang and asked him if he is confident to do the conversion, he promised to to let me down or desert me. So watch this space, see what happens.
Me and him, we both know what's going on inside engines. We both know the tuning game and we are going to play it.
Typo, I meant he said he will never let me down or desert me. I am just going to leave it in his capable hands and see if he gives up.
I understand it's going to take full commitment's, i understand that what I'm thinking of doing is not going to be easy. You wouldn't get this from any other guy, I just wanna tell you how I'm feeling I should modify my Leon to be different, i guess i got to make you understand when you see my bhp figures afterwards.
