As some of you might know I've been having problems with missfires at high revs on my LCR.
Starts to missfire I beleive just after 4.5k up to 6k but I think I get the odd missfire at low revs as well but its more noticeable at high revs. I sometimes get the ECL flashing with a code missfre on cylinder 2 and multiple missfires detected.
Things thats have been tried so far
new coilpacks including TFSI coils
new plugs
swapped injectors for known good set
replace igntion harness/loom back to underneath the battery
new egt probe
maf has been checked
coolant temp sensor replaced
new fuel filter
new cyllinder head (old once was cracked on exhaust port)
new bosch battery 780A (old one was tired)
things I have yet to try
run some more earths (this will hopefully be done this weekend)
change crank sensor (this might have been checked by bill already)
change cam sensor
check fpr
replace ignition loom all the way back to ecu
check injection loom
replace vvt
Just wondered if anyone else would like to give some opinions on what might be causing it?
At the moment the water injection is turned off (fuse pulled), car is running off actuator only (ebc disconnected, charge pipe connected directly to actuator). I have also done an N249 bypass.
specs of car
LCR 225 (bam)
JBS 05 hybrid turbo (k04)
JBS hi-flow k04 manifold
Forge FMIC
devils own water injection
badger 5 3" tip
550cc injectors
bkr7e spark plugs
new plugs
new egt probe
new fuel filter
change cam sensor
check fpr
replace vvt
specs of car
LCR 225 (bam)
Forge FMIC
badger 5 3" tip
550cc injectors
bkr7e spark plugs
