Gas is already gone so just gonna scrap it all I'm sure I read it was a mk4 golf belt or summing I need
Any suggestions about the secondary air pump
Chain doesn't need to be touched mate, comes out with the head.
It only connects the 2 cams
Ok do I remove cams before removing head
So if I loosen the head bolts in sequence the head will.come of with out touching the chain and cams yea
Yes, remove the cam belt 1st though![]()
But leave inlet and exhaust manifold on![]()
I removed the hydraulic damper first to slacken off the belt. I removed the other tensioner after the belt was off
