Ronin225
4,652
22
Worcester
If you dont mind me asking, how much and where from??
I've always found the side to side kit very expensive so never bothered
ReDBull
Every day's a school day.
Nov 21, 2006
2,991
14
Lincoln
I bought them from Awsome they where around £130 for the pair. I know you can do a DIY job but didn't think they cost that much. I'll have to see how it drives, the slop has gone from the shift.
ReDBull
Nov 21, 2006
2,991
14
Lincoln
Nearly there tea brake time.
ReDBull
Nov 21, 2006
2,991
14
Lincoln
I have them both set at 50% and the side to seems to of made the biggest differance. I'll adjust the front back shorter but I wouldn't want the side to side any shorter.
It's a bitch getting the brackets over the rear beam on the ARB as well!
n11tht
278
under the bonnet
fitted a new tie rod end, cleaned it then took it for a wheel alignment. everything seems to be perfect with the car now and for the first time in 6 months I can enjoy my car again :D
ianmessy
59
Carlisle, Cumbria
Ordered, took delivery & fitted my VW Conversion Aero Wipers from TPS part No PN 1J2 998 002
Did have the aftermarket sub £10 Aero Ebay jobbies on but the big connectors always looked wrong, one blade split so changed, full VW arm conversion would be nice but too expensive & these look really neat.
Well worth it for under £20:D
csd_19
2,280
28
Angus / Edinburgh
Any pics of the new bits fitted? :)
MalcB
Quantock Hill Billy
Sep 13, 2011
161
Taunton
Just found this thread.
Owned the car ("03" Plate Cupra) for only 3 weeks.
Things done to date:-
Cured water leak in drivers door
SAI pump fix - Couldn't stand the racket on start up.
Fitted Forge 007p DV - OE one leaking to the extent of only 0.25 Bar Vacuum on overrun
Fitted Pipercross Panel filter.
Car now in at TSR for a wheel bearing, Cat Back Exhaust and REVO Stage 1
should get it back tomorrow morning.
danarmstrong
179
South Wales
Fitted my new Creations Motorsport TIP and done N249 :)
Also fixed a split pipe coming from underside of the inlet manifold which was giving me fault code 17705
