If you dont mind me asking, how much and where from??
I've always found the side to side kit very expensive so never bothered
I bought them from Awsome they where around £130 for the pair. I know you can do a DIY job but didn't think they cost that much. I'll have to see how it drives, the slop has gone from the shift.
Nearly there tea brake time.
I have them both set at 50% and the side to seems to of made the biggest differance. I'll adjust the front back shorter but I wouldn't want the side to side any shorter.
It's a bitch getting the brackets over the rear beam on the ARB as well!
fitted a new tie rod end, cleaned it then took it for a wheel alignment. everything seems to be perfect with the car now and for the first time in 6 months I can enjoy my car again :D
Ordered, took delivery & fitted my VW Conversion Aero Wipers from TPS part No PN 1J2 998 002
Did have the aftermarket sub £10 Aero Ebay jobbies on but the big connectors always looked wrong, one blade split so changed, full VW arm conversion would be nice but too expensive & these look really neat.
Well worth it for under £20:D
Any pics of the new bits fitted? :)
Just found this thread.
Owned the car ("03" Plate Cupra) for only 3 weeks.
Things done to date:-
Cured water leak in drivers door
SAI pump fix - Couldn't stand the racket on start up.
Fitted Forge 007p DV - OE one leaking to the extent of only 0.25 Bar Vacuum on overrun
Fitted Pipercross Panel filter.
Car now in at TSR for a wheel bearing, Cat Back Exhaust and REVO Stage 1
should get it back tomorrow morning.
Fitted my new Creations Motorsport TIP and done N249 :)
Also fixed a split pipe coming from underside of the inlet manifold which was giving me fault code 17705
