Brilliant!
Where's the reservoir?
OK, finished building and install my custom air freshener system.
Bit silly i know but was bored with 6 weeks off work and with magic trees only lasting about 2 days thought i would design something. works well actually and love the Febreze Caribbean Paradise smell. Smelly farts in the car are a thing of the past
Parts Needed
Triumph Tudor 500ml washer bottle and stainless bracket - £15
Ring Automotive universal 12v screenwash pump -£12
5m clear 3.2mm washer tubing -£3
One way valve - £2.50
12v electric shut off solenoid valve - £12
1/4" BSP to 4mm Hose tail connectors x2 - £5
1/4" BSP Bonded washers - £1.50
Push to power switch - £2
5m 25amp red power wiring - £3
Various spade connectors and terminal blocks
2x 300ml Febreze Caribbean Paradise air freshener - £4
Febreze novel spray (taken apart from used Febreze can)
Total = £60
Vid in action
Awesome Car but I dont like wheels
how much did you pay for the cruise control kit? did you fit it yourself?
Must say I am impressed with the air freshening system!
I would recommend getting the LCR disk guards if u can - I had the lip cut off my FR ones and it makes the rear disks look quite small.
cheers. might move the spray into the cooling tunnels somewhere so the scent comes out the vents but without the spray. ill experiment![]()
I've started putting my air fresheners on the pollen filter to get the smell through the vents.
Stops the car being overpowering of air freshener from being sat with the magic tree in it.
