It will go back in, just have to find the right angle and it will pop in. If its the whole arm then it shouldnt come out without removing the three 13mm headed bolts and the cap that's buy the fill bung.
Good man, well done![]()
Cheers mate. Was a **** of a job but at least it's done.
Just this weekend to go then it's rolling road time
Hopefully mine will be on, as the clutch felt shite earlier... bit worrying. Will see how it is over the next few days. It is getting replaced but after the 19th for sure. Bugger.
Be good to see the car again mate.
Hopefully clutch will hold out as long as possible. Have a look at the Southbend clutches when your looking for an upgrade. I highly rate mine, OEM pedal feel and capable of holding 450LB/FT.
Awesome one is rated to 400lb/ft so good option for you tom, the southbend kits (i have the same as james) are not cheap, double the cost of the awesome kit
If your staying k04 then i doubt the need the extra torque handling ability
Without sounding harsh you maybe better spending the money on some proper ARDS training and getting some hours/experience under your belt before joining a race team
You could then put your training to good use on LCR with some sticky R888's on
Saxon offer full driver training and their race team mainly consists of mk2's so my idea was to buy a mk2 to work on and build, whilst driving / training in one of their race cars.
