Hi guys, i know this is a bit off topic but i didnt think it was worth starting a thread, how low does your plastic sump guard hang? Because mine hangs about 3 or 4 inches off the ground and has a habit of scraping on the roads around where i live, its fully bolted up, just wondering if its a problem or am i just not used to giving an F' when my cars scrape the deck? Ex pug 306 and corsa driver... Was planning lowering her a touch on ebachs so will become a problem. Car is an FR tdi 150.
That sounds expensive m8
£415 fully fitted and that includes front wishbone, rear axle bush, steering rack bush and dog bone mount bush.
Needed doing as i changed the wishbones 2 weeks ago for some off ebay and one of the bushes failed within 200 miles and couldn't be bothered to do it all again
Changed all the interior lights to led white ones, painted the s3 callipers black ready to go on and got a few little trims from the scrappy! Also received this in the post. Cheers BruceR
serviced the forge dv fitted a new yellow spring :D and searched for a boost leak that i think i have and found this
under the mani small split in a hose dont know if its a vac hose or not lol
